Hi Guys
Firstly thank you for the advice, it is much appreciated. In all honesty, the servos and turbine size were also my areas of concern. Did not see the Festo thing coming though
In terms of fuel filters I suppose you could always use the OEM filter that comes with the Turbine. Dansy, the reason I am showing the Powerbox GPSII connecting to the CTU is as far as I am aware, you can change the second exbus port on the CTU to servo or I am hoping jetibox/sensor. I know you cant change the first one. Worse case I can run it to the CB200. On the Powerbox GPSII, there is an option on the software to change the setting so that it emits the Jeti EX Telemetry signal.
James
