Hello,
for turbine models we now also have a fuel flow meter / tank indicator.
FLOW-meter
Like
our ECU converters, the FLOW-meter is compatible with the most common RC systems, the desired RC system is selectable, see example JetCat P60 with core:
The FLOW-meter can be used as a stand-alone device, but it can be operated also in parallel to an ECU converter, eg compare or optimize the calculated fuel consumption of the ECU converter with the real fuel consumption.
Our FLOW-meter has (like other things/parameters) an easy-to-use calibration function, with which a very high accuracy of the flow measurement can be achieved (see demo video on our website).
Depending on the turbine size, you can choose between 3 flow sensors - the FLOW-meter can also be ordered without a flow sensor , e.g. for existing flow sensors, as there is a wide selection on the market, like these:
flow sensor
Further informations, demo videos and detailed manual on our website, via the following link:
www.vspeak-modell.de/en/flow-meter
