Temp problems
I would advocate either placing the aircraft in the sun to see if you can duplicate the issue , and if so make a note of the telemetry temp of the CB 200. Or, alternatively use a heat gun and gradually raise the temperature on bench to see if you can cause a similar problem.
you could set an alarm on the temp to not fly.
it might not be temperature,
just sayin,
Bob Neal
