question for the builders?
DO you fill in this area with balsa or wood, or do you mount the wing such that all the pressure is between the wing and the wing saddle?
also, do you use a blind nut on the top of the mount for the wing?
and do you use Nylon bolts or metal bolts with T nuts?
do you fill this area? do you use t-nuts?
