Originally Posted by
acdii
If that is anything like the 38, check the pulse lines between the crank and intake, then might be backwards. One line provides crank vacuum, the other pulses the carb pump. On the 38 the center line from the crank goes to vacuum, the bottom goes to the pump port. It might be pumping into the intake instead.
the 30cc only has one line
