Wet grass is a killer of planes built with some types of foam board. Unfortunately, it seems that the best foam board to use is the type most susceptible to moisture related problems.
Foam board is just an OK building material in my opinion, much like cardboard or coroplast. They all work well within their limitations but none work as well as good old balsa. Foam board is probably the easiest and fastest to use.
