Originally Posted by
masteromodels
I have had a problem with the with the left wing dropping , i cannot find or see any warps in the wing and I have a tight fit to the fuse. on both sides . Now I have added a weight to the left wing , but I have not flown it with the weight . First and second flight the plane really dropped the right wing and it took almost 3/4 left trim to get it flying straight ..
Hi, one way to check the straightness of the wing is to assemble the plane and put it upside down in a cradle on the ground or on top of a table, so that the bottom of the plane is up. Then check the wing from all angles, especially from the rear. You might see something that was hard to see with the plane right side up on the ground. Are the ailerons flat without any twist in them?
-Ed B.
