I did check the engine thrust angle and it is fine . There must me some reason , I'm going to try the lead when i do fly it , if it stays the same I may increase it after each flight . it is a big and long wing and if one side is heavier or longer it could make the difference . There is no way it should need that much left trim . Thanks again Bob
