T18SZ V3.9 Update Software
For me personally, the T18SZ V3.9 Update Software is a minus! I will explain. Often for the same model I use two copies with different numbers of battery cans, for example - 3s and 4s. Two copies because in telemetry you have to set different alert voltages. It turns out that in the field, when changing the number of cans, it is necessary to bind the receiver to the transmitter each time, which is not very convenient, since the screen at 18sz is not bright and you can not see anything in bright sunshine. Therefore, I remain on the T18SZ V3.8 Update Software.
