Originally Posted by
CARS II
Do you have any suggestions on the build, anything that should be change or fix?
Tks.
Close to 300 flts on mine, the main thing I would recommend is to ditch the air retracts and go with a good set of electric gear. Since your running the 60 size turbine, you may also want to consider using a smaller tank. The 2.7L tank they sell is great, but oversized, especially for a smaller engine. I use a 2L tank with my K85 and generally land with close to half a tank of fuel remaining. Otherwise, it's a great jet as is.
