Hello Dazz,
Are you spinning the rotor with compresses air or with a motor drive and is your cradle sensitive enough to reach such low values and if re calibrate are you finding the same results? what Hz are you spinning ?
I,m builded the cradle with bearings support , still playing around to get better results , I must say its fun to actually reach better specs each time
