RE: applying promark rivets, problem
Promark makes a great product. It just takes a little learning curve. I cut the rivets into strips. Just give each strip a little shot from a heatgun before application, and warm the surface you're applying them to. The heat activates the adhesive. It takes very little burnishing. I usually just use the back of my fingernail. Good luck.
