Originally Posted by
Didier
Thanks for your suggestion! I ordered the FW in the first place but I was recommended to use the WW2 prop. Due to noise restrictions I am scared the FW props are not the quested ones. What is your experience regarding props noise of the FW props?
Hi,
I suggest to try a RAMOSER Varioprop adjustable pitch Propeller. On my FG90 I run a 25F 3-blade hub with 21.8“ SG (wide) blades. With cooling fan in my FW190 I get 5700/7000 RPM at 12“ pitch. Without the fan you can expect 14“ pitch same RPM. And the blades are pretty cheap if you like to try other ones...
Regards,
Juergen
