RCU Forums - View Single Post - YS DZ200cdi
Thread: YS DZ200cdi
Old 07-12-2020 | 02:51 AM
  #278
drac1's Avatar
drac1
Originally Posted by kobi
Hello
Problem with my engine:
engine 200 cdi , prop 21.5x10.5 , fuel morgan cool power 30% heli
While flying, the engine stopped, I landed an emergency landing.
When I checked what happened, I found that an exhaust valve stuck in the open position.
The small piston goes up and down by the camshaft, remaining stuck up
I released the piston I cleaned it and oiled it and now the engine is back to working properly
my question :
Do you also have an event like this?
And what do you think should be done to prevent this problem from coming back?
Tanks
Kobi
I've never had that happen. How much running has it done? It maybe a heat issue, causing it to jam?
As long as the lifter is moving free, there's not a lot more you can do.
If it does it again, I would replace the lifter.
