Originally Posted by
cbk07
I also have an Ultra Flash with JP retracts and LG15. The gear work perfectly on the ground....but once airborne, at least one gear goes not full retract most of the time. If I drop to landing flaps and slow the plane way down, they will full retract. Everything seems to be aligned correctly. Is air pressure stalling the gear? Do I just need to increase Amperage? Does anyone know where amps should be set for the mains? Thanks in advance!!
‘When I had the JP in the T-1 which is the same size as the UF.....I got this from JP..if I remember correctly I was at 1.1a on My setup (now on a different brand)
The retract of our ER-150 start max current is about 1.2A. the working current is about 0.8A. not suggest to use with other brand controller
