RCU Forums - View Single Post - Beginner questions
Old 07-19-2020 | 03:32 AM
Hydro Junkie's Avatar
Hydro Junkie
I would look at one of three kits:
1) The Kadet MKII This one is the smallest of the series and the easiest to build due to having a full box fuselage. The sides are balsa sheets with all the part locations laid out for you, The top and bottom are also sheeted, after the sides are completed and glued together
2) The Kadet Senior This one has a stick framework fuselage behind the cockpit area and clear plastic windows. It is the largest of the Kadet series and the hardest to build
3) The Kadet Seniorita This one has the Senior's construction with a smaller size, closer to the MKII.
All of these can be built as a tricycle geared or tail dragger so you can configure it as desired. For more information on these, the links are below:
https://sigmfg.com/collections/sig-k...et-mark-ii-kit
https://sigmfg.com/collections/sig-k...det-senior-kit
https://sigmfg.com/collections/sig-k...-seniorita-kit
