RCU Forums - View Single Post - Jeti DS-12
Thread: Jeti DS-12
Old 07-19-2020 | 10:08 PM
  #43
camss69's Avatar
camss69
My Feedback: (46)
Originally Posted by Jannica
Harry C.
Do you think you could make a video about how to use a two or three point switch instead of using the trim buttons to arm and disarm a turbine ECU?
Jannica
Sweden
It’s really easy here’s how I do it in 3 pictures.
Set your max positive to 100 and max negative to -125% on your throttle.
Remove the digital trims from the throttle channel.
Set your throttle cut and idle as I have it below and assign to whatever switch you want to use.
Good to go!
