RCU Forums - View Single Post - Jeti DS-12
Thread: Jeti DS-12
Old 07-20-2020 | 09:49 AM
  #50
camss69's Avatar
camss69
My Feedback: (46)
Originally Posted by wfield0455
So normally manual cool down would involve advancing the throttle stick directly from low trim. Can't you simulate that by leaving the turbine control switch in the stop position ( trim low) advancing the throttle stick and then moving the turbine control switch to the run position ? Doing that should look exactly like advancing the throttle directly from trim low and trigger a manual cool down.
I think the throttle position just stays at throttle cut and it doesn’t see the stick input maybe?
I’ve never tried to do the manual cooling with my setup I’ll try it next time I’m out.
The -125 and 100 end points work with Kingtech learn RC, I suspect -100 and 80 would as well. You are correct and it should be noted in this thread that -80 and +80 end points in Jeti are equivalent to -100 and +100 on I think everybody else? I know JR and Spektrum, not sure about Futaba.
