Originally Posted by
smiller
I have been flying with this radio for a while now in my prop planes and will covert to my Jets soon. One thing i would like is a stiffer throttle movement. the adjustment is maxed out. Do they have stiffer spring plates for this ?
Thanks !
Scott
Agreed the throttle is not stiff enough. I don't really like ratchet's.
I modified my Core. I soft soldered some thick brass shim to the existing ratchet plate ( took some prep work). I also had to add a couple of washers to space the assembly.
Now have all the adjustment I want
Chris
