I put mine altogether for the first time! Wow!
I have all the surfaces set and adjusted for proper throws. Read in here that the throws per the manual were low so I cheated them all up just a bit for low and mid rates then a bit more for high rates.
The landing gear seems to work just fine. I put 100psi in and cycled them 5 or 6 times. I left it over night and in the morning got several more cycles. Completely stock system. Happy about that.
I do need to slow it down a bit especially on the up cycle, I have some Robart restrictors and will try them with the stock tubing.
Just need to finalize the mounting of the radio system and wire routing, and check the CG.
Getting close!
