Originally Posted by
Dave Wilshere
Not a single comment from all of the Core Tx’s I’ve sold wanting a stiff throttle! Some wanted more spring tension on main controls, but throttle seemed not to be an issue.
I’d need to look at my tx, it must be mechanically possible if that’s how you need it.
As i mentioned above, quite easy to modify. You will have to take the back off the TX
You are only modifying the plate.
Just need to scuff the existing plate so it will solder. Add some thin brass shim
Pack it out with a couple of small washers. Use the same adjusting screw
No real modifications as such and if you really wanted to return it to exact factory specification, just purchase a new plate
Done, gives you all the adjustability you would ever need
Maybe one day PowerBox will offer a new thicker plate
Chris
