I may take a look at that. PB America said an option was too drill a new hole beside the existing one and move the tension screw over to make its contact point on the plate allow greater tension. I’ve had the back of the Tx off a few times now but haven’t actually modified anything yet. Your idea sounds good as long as the solder joint is perfect. I thought about a longer screw but it’s right at the end of the spring plate.
