RCU Forums - View Single Post - Comp ARF BAE Hawk build thread
Old 08-08-2020 | 08:50 AM
  #2332
fireblade5437's Avatar
fireblade5437
Originally Posted by husafreak
Hi Alan, seen your posts on PB Support, and DW, good to see our Hawks are still flying and getting facelifts now
I plan to thoroughly refresh mine with the PB Rx, fuel lines, servo connections to the wing, whatever else I can find after all these years and 400+ flights.
Alan what “CTU” are you using for turbine telemetry with the CORE? Was it easily implemented? I have a Mercury and 2 PBR-26D Rx for my Hawk. So this will be the first time I fly the Hawk with a gyro. I never felt it needed one.
Smart install BTW. And the CORE does appear to have truly great connectivity with its PB Rx. How it can “see through” CF is mysterious but I ain’t complaining!
Hi! Hope your doing good!
The CTU I am using is one done by Carsten and Sandor (Digitech) very good and easy to programme
got one on my T1 with the JetMunts 140XBL and the Hawk with the P120SX
I have Mercury SRS in T1 also got one in Elan with 100XBL
The Hawk was originally set up on Cockpit non SRS so got a Power Expander and as you had probably seen on Powerbox forums had problem with servos jumping until I found by setting all frame rates to 12ms in Expander and Cockpit cured the issue
Also no intention of ever putting gyro in the Hawk it just does not need it...
Alan
