On to the air frame itself
Its nicely finished, not quit on par with the smaller Freeing T33 but that T33 is a high bar for a foamy.
Assembly takes only an hour or two and everything fits OK but the joint between the front and rear fus are not 100% but close enough, no glue needed.
When together Its an impressive size and as long as its wide with the wing dead in the middle, its like a large cross!
The tip tanks give the T33 a feel of "size" and like the smaller FW offering will perhaps make it look even bigger in the air than it actually is.
