RCU Forums - View Single Post - Design KI1603 X-WRAE
Thread
08-08-2020, 04:22 PM
58
H5606
Haste makes waste - rushing the project resulted in overlooking an essential requirement and that is to get wiring from the flying/control surfaces in the control distribution center section to the receiver located in the fwd fuse section. Ended up locating holes in the floor of the center section and adding a subfloor as a pass through for wiring into the pylon and down into the hinge knuckle -
Locating the four pass-through holes in the floor of cntr section -
Four holes marked -
Holes tangent to walls of cntr section -
Adding 1/16" T subfloor walls -
Last piece -
Addition of subfloor support spacers -
Fitting pylon -
Pass-through for servo connectors and wiring in pylon -
Top holes allow for connector clearance on sides from subfloor -
Blank sheeting to fit hole for pylon on subfloor -
Lay out for hole -
Subfloor hole fit of pylon -
Slight oversize perimeter layout of subfloor from holed blank -
Revised holes for connector clearance -
Sub-floor installation on control distribution center section -
Reply
Like
mgnostic
(08-09-2020)
H5606
View Public Profile
Send a private message to H5606
Find More Posts by H5606
View iTrader Profile
