We’ve test run the engine. Had a bubble that caused a shut down. Rebooted and restarted, it ran perfectly. It’s an amazing powerhouse. We took the flying surface throws off the webpage. Only thing not seen was flap/elevator mixing but we set up OTF programming for that so should be easy to trim once airborne. Running the new Spektrum PowerSafe 12 channel and an AS3000 gyro.
