RCU Forums - View Single Post - Crickets....
Thread: Crickets....
Old 08-22-2020 | 03:22 PM
  #144
R_Strowe's Avatar
R_Strowe
Originally Posted by ira d
I just think its strange the AMA is in constant contact FAA but does not seem have any real progress to report also if they are asking for specific things from the FAA that are being denied I think all that info
should be public knowledge. So when they print in the magazine that they are in constant contact with the FAA to advocate for the hobby some would like to know what is actually being accomplished and
what the FAA is telling them. I would also expect that if we needed to go to the AMA websites to find the answers to questions that may come up from reading the article they should have said that.
I did not take the time to register on the AMA website because I doubt there is a lot more info than we already know im sure if it was someone would have referred to it already in all the discussion
that takes place on the subject here and on other forums.
Could it be possible that the AMA has learned that regardless of what the FAA tells them, the end result will be something completely different and probably opposite of what was desired? In which case I would say it is better to not report anything other than "we are in constant contact with the FAA", as that would be factual. If/when they actually have something concrete and substantive to report I assume they will do so.
R_Strowe
