RCU Forums - View Single Post - CARF Bolt! Build thread
Old 08-24-2020 | 02:00 PM
  #31
Dave Wilshere
Work got in the way the last two days, so slow progress. On the full production kits the surface control rod slots will be cut 2mm wide to allow you to open to suit the arm offset you use. Mine was already opened to 5mm so I have ended up with a wider slot than I wanted. I may put fairings over the front section anyway to clean them up.
MacGregor 6928 Brushless servos on the stabs the same as the two prototype Bolt! Airframes.
Note the kit comes with carbon sleeves for the pushrods. I’ve just not set the length yet.
bodywerks (08-25-2020)
