Originally Posted by
JayGull
Hey guys, I am getting ready to maiden my Spitty and completing the control surface throws set up. Curious to see if everyone is using what is specified in the manual? My manual has both low and high rate reccomendations but even the high rates seem too low. For example; 15mm on both the ailerons and elevator and only 25mm on the flaps. These are the high rates. Anyone have a different set up reccomendation? I usually set up about 30% expo just to smooth out the shaky thumbs 😎.
Thanks for any help!
Interested in comments here as well. Seems like I read that the control throws in the manual were low. I did set mine up per the manual for low and used the manual high rates as mid and then went with a higher setting as well.
Will hopefully maiden in the next couple of weeks.
