Originally Posted by
JayGull
Hey guys, I am getting ready to maiden my Spitty and completing the control surface throws set up. Curious to see if everyone is using what is specified in the manual? My manual has both low and high rate reccomendations but even the high rates seem too low. For example; 15mm on both the ailerons and elevator and only 25mm on the flaps. These are the high rates. Anyone have a different set up reccomendation? I usually set up about 30% expo just to smooth out the shaky thumbs 😎.
Thanks for any help!
I recall that the throws in the manual were low and I later increased them, particularly on the ailerons. Get as much travel as you can for the flaps. I changed the installation to increase the flap throws to around 60 degrees. Good luck!
Best regards,
-Ed B.
