Originally Posted by
dvcam99
Hello Bob,
I would not recommend this with ECU`s like ProJet, JetCat and EVO Jet for example. Because all these ECU`s have a security "feature" called galvanic separation.
If you plug in a current telemetry sensor without a galvanic separation you connect the ECU current side to the receiver side.
The galvanic separtion is then bypassed.
BR
Dirk
CB Elektronics
Well, I did this on a jetcat P60 and it worked fine. I added the sensor to the positive line between the ECU and fuel pump. But I will heed your warning.
Thank you!
Bob
