Originally Posted by
R_Strowe
That is YOUR interpretation. Not everybodies. Note he does NOT mention AMA, only CBOs. YOU choose to see the boogie-man under the rock. But when taken at face value, there was no 'forced membership scam'. That is only in the mind of conspiracy nuts.
In response to an inquiry to the FAA’s UAS help line, that concerned whether membership in a CBO is required to follow Section 336, the FAA responded, ‘the FAA does not interpret P.L. 112-95 Section 336 as requiring membership in a CBO, nor the the FAA list any CBOs. You must only follow the guidelines of a CBO.’ This statement ignores Congress’ requirement to operate within the programming of a nationwide CBO... (emphasis added)”
- Rich Hanson, President, AMA, February 2018 Model Aviation Magazine, pg 6.
Currently, if you are not a member of a CBO and following its rules, you are required to fly under Part 107 (emphasis added).” - Randy Cameron, Executive Vice President, AMA, February 2018 Model Aviation Magazine, pg 124.
To fly a radio controlled aircraft in the United States, there’s only two ways you can do that right now. You either get a 107 UAS Remote Pilot Certificate … or you follow Section 336 of the Public Law, which outlines a process where you can be part of a community based organization and then follow their guidelines. So basically AMA is the only one at this point … So you either have a 107 certificate or you’re a member of the AMA (emphasis added).”
- Tony Stillman, Flying Site Coordinator, AMA, undated interview approx 9 months ago w/ Hobby Geek (approx 15 minute mark)
And these don't include the video where Executive Director of AMA also says ".
... you have to be a member ...."
