Originally Posted by
etibedossa
Hello guys,
do you use elevons mixing with ailerons in the 1/5 F18 ? On mine, roll rate is not very high with ailerons only, with maximum travel mechanically available. Many thanks in advance.
Mine is slow to. I haven't tried that but I've thought about it. One thing did help a bit. I changed out the servos from the Spark to a faster Savox. That helped a lot on the roll rate.
Andy
