Originally Posted by
Carlo Vangompel
Hi Didier,
Great setup you have with your Zero
I also bought a Ramoser varioprop 25F with 21.8" 3 blades for a FW 190
Since this is my first varioprop, can you give me some advice how to setup the prop?
Thanks!
Hello Carlo.
This is my first Ramoser as wel. Just follow the instructions. I use 22,7” HS blades though and adjusted it around 5400 RPM on ground (6900) in air with a pitch around 14,5”. This seems to be perfect for the Zero. Hopefully the 21.8” gives enough load for the Saito 90. Good luck!! 👍
