RCU Forums - View Single Post - 8th Scale Aviation's, "CzechMate" Short-kit, Group build
Thread
09-08-2020, 05:49 PM
351
Iron Dog
To make the fairing to blend the wing into the rear of the fuselage, Tim and I each used one metered pump of West Systems laminating resin in a wide, shallow 3 1/2 oz. soufflé cup, and mixed-in micro-balloons until achieving a "peanut butter" consistency. This mixture was poured onto the center section at rear of the wing; then a "Bondo" applicator/spatula was used to smooth and even-it-out, blending it into the balsa sheet that formed the bottom fuse sheeting and overlapped the rear of the wing.
Tim pours the micro-ballon mixture onto the rearward center-section of his wing.
Using a Bondo applicator he works to smooth it out, and fill-in the "low" spot between the leading edge of the bottom fuse sheeting and the main wing spar.
Here in Sacramento, CA we had the hottest August ever on-record, so there isn't much time to work before the epoxy begins to set-up. Gotta work fast!
A-l-m-o-s-t there!
Okay, he's happy with it.
Reply
Like
Iron Dog
View Public Profile
Send a private message to Iron Dog
Visit Iron Dog's homepage!
Find More Posts by Iron Dog
View iTrader Profile
