RCU Forums - View Single Post - Return after 24 years
Old 09-09-2020 | 10:47 AM
SoCalErv
Originally Posted by tedsander
They're cheap enough - just buy the already made packs in whatever "S" you want. For support equipment, Hobbyking is good enough. One less thing to do, since you really should be soldering both main conductors AND balance leads.
A 3S probably will run the pump, but slowly. Why not just go with 4S? It would be over voltage but not super extreme....or go with the 6v version pump, and the even cheaper 2S.......
The LiFe packs have less availability in sizes as the LiPo on the site you provided so I thought I would assemble exactly what I wanted.
As for the Sullivan 6 volt fuel pump I have searched but can only find the 12 volt.
I will need to understand your comment "solder both main conductors AND balance leads". Google here I come.
