Originally Posted by
masteromodels
Did you nee a lot of left Aileron trim ?
Yes about 1/8". In the photo you can actually see the trim, the pic was taken after the fight.
Based on your posts I was ready for it.
The plane seemed to track ok with no yaw tendency.
I wonder if one wing is out of alignment or built with a slight twist.
I will set it up and run an incidence meter across both wings and see what that tells me.
The plane balanced laterally.
