A new ABC engine and cold weather is not a good combination. The engine needs to heat up so the sleeve will expand (part of the technology of ABC). If you don't get this heat then the piston will wear the sleeve and damage will occur very quickly. You can put some aluminum foil over the fins to keep it from cooling too quickly. Running engines inside is not a good idea even for a little while. Get the engine warm by keeping it inside and let it come up to room temperature. Go outside and immediately start the engine. Make sure the igniter is fully charged.
EXCAP232
ORIGINAL: beginner_1
i got my .42 tt engine going to day i just bought it because iam a begginer .i could not get it starthed for a little bit but i cept ajusting the engine than it would start that it would run good but it would stall. why would it stall all i did was bring it out side when i got it started but then i guess the tempiture was -10 .c does the cold air stall it?. or wat is happening
