RCU Forums - View Single Post - Does a tuned pipe make a BIG Difference?
Old 11-09-2003 | 05:16 AM
  #47
DarZeelon's Avatar
DarZeelon
Default RE: Does a tuned pipe make a BIG Difference?
Joe,
From all the replies you must understand that a tuned exhaust system does make a big difference.
Its effect is, of course, at mid-high to high RPM.
If you select a correct tuned silencer system (and adjust the low end needle properly), the idle and transition will remain great.
So the only major down side of such a system is cost (the weight penalty should be very slight).
If you select a Jett-Stream, or an Ultrathrust, the toll will be highest, the Tower/Hobbico muffler will be the the most cost effective. All other possibilities are somewhere in between.
