Originally Posted by
ravill
And does it matter that the ECU setting is kingtech G2/3, as there is no G4 option on the ctu through the dashboard?
Give one engine a spin and check the RPM or use a heat gun on one and check the temp to see which one is showing.
G3 and G4 are the same, both use the same GSU.
