Hi
If I calculated correct I have today 89dm2 on both wings (the aera in the fuse is not removed) so I think maybe it isnt that bad so I think I just make the wing a bit wider in the root ,do a dobbel taper so I move more off the aera to center, the prototype is also pretty low in weight so maybe a bit higher wingload would helped, so maybe I can build the next one a bit heavier!!
