RCU Forums - View Single Post - Help with my GP Pitts PLEASE!!
Old 11-09-2003 | 11:03 AM
NavyE6FE's Avatar
NavyE6FE
Default RE: Help with my GP Pitts PLEASE!!
Fatboydrvr, where did you route the rcvr ant.?? If its in the tube running through the fuse., this could be your problem. I initially had my ant. inside the fuse. and had the same problems. Routed the ant. out the side and back to the tip of the horz. stab and no more glitching. As for the warping the only thing I can think of is that your ailerons are jamming towards the end of the deflection. Check and make sure the ailerons move freely and easily up and down.
Steve
