Start Failure
Thanks for the quick suggestions. I think my regular battery should be adequate, it is 5000mah 2S Lipo. I went to the large battery because I needed nose weight. I will certainly try a different battery. I did test pump fuel manually but not very much because I can only see the fuel line a shorty distance from the pump. I didn't observe fuel flow during the start attempt, will do tha today.
After thinking about it more the decaying RPM that may indicate inadequate battery even though it is new.
