The true test is to run some on the ground if there is no problems I would use it. Check each gallon separately when you open it and if you encounter any run problems during using a particular gallon I might be inclined to suspect that particular gallon. Maybe a friend could donate or sell you a partial tank of fresh fuel to compare against the gallon of old fuel. If you do this try and rinse the tank with a bit of new fuel.
