Ok, So i'm in the middle of programing LG, How do the steps go for the gear in the controller for the T-1 mini. When I power up the LG-15 It says check switch, I have it set to cycle gear switch to activate, so I flip it gear down, gear up, now its ready to program the steps for gear, question is how many steps do you use for the t-1? I have Step 1-front gear door open, step 2, gear down, door open, where do I go from here, do I need more steps or just when I flip the switch again, will it gear up, door closed. if someone could send me there sequence of steps, that would be great, Thanks.
