Originally Posted by
jonalib
The Tamiya XF 61 Dark Green is a pretty good match to the Taigen Sherman all metal edition. It is not a great metameric match under fluorescent light and it is ok under incandescent but is a great match under daylight. I tried a bunch of colors before finally asking the shop owner if I could take some bottles outside to check color. I needed it to paint the steel (resin) plates I'm attaching on the side of the hull.
Sherman 76 Taigen or 75? Did you use a primer?
