Rick
There are never too many questions! Balancing the way you have will be better as his is probably nose heavy overall. You will not get into trouble with so much fuel forward, you will feel the balance as the fuel burns and chose your ideal position. Not used the AB, but flap or AB on a Hunter has little or no pitch change. If you fly on tarmac the AB will hit the ground.
Dave
