Curious if anyone has an issue with jet climbing too easily with speed? I carry down trim even with the CG maybe just hair nose heavy. The turbine and exhaust tube are at whatever incidence the kit was made too. The ailerons and flaps are all neutral to the wing tips so they are all in alignment. Inverted flight requires more down stick than it should to maintain level flight, especially as you go faster. In other words, it climbs constantly when up right and you increase speed. If it was a prop plane I’d add some down thrust or ensure the wing didn’t have too much positive incidence.
if you had this issue, what did you do to correct on this kit?
