RCU Forums - View Single Post - Engine for pylon training
Old 10-20-2020 | 05:46 AM
  #33
whiskey29
Originally Posted by GREG DOE
Whisky, Tough question? With the tank on the CG it's possible to move the airplane's CG further back. A more rearward CG will allow the airplane to turn with less elevator throw to accomplish the same turn radius, so the airplane doesn't slow down as much in the turn with the more rearward CG. The conventional CG location for an airplane with the tank behind the firewall might get too sensitive as the fuel burns off. The two pluses with bladder tanks is that you can set the needle valve much closer to peak RPM, and the tank can be located further from the engine.
noted Greg.
attached are what friends here are using.
The yellow no 4. Is mine to fly, given by a friend that lives in other city, its running abuse able os.46 fx with 50ish muffler, not legal, just for practicing. That engine RPM gets close to OS .46AX
I have a seeker as well, currently finishing other two. I uploaded pic the plane on Shartman posts a long while ago
