RCU Forums - View Single Post - Thrust Vector Argument, please help!
Old 10-22-2020 | 12:09 PM
BMatthews's Avatar
BMatthews
Wait... We don't normally consider the thrust line to the stab. You'd want to compare the thrust line to the wing airfoil's center line. And then compare the wing's center line to the stabilizer center line.
If this were a model set up to be flown by a pilot skilled at aerobatic flying the overall setup would be 0-0-0 for thrust-wing-stab along with a couple of degrees of right thrust to counter the torque to the left. And the pilot would trim the CG so the model was neutrally stable in pitch. And that would be a nice setup for aerobatic flying.
The fact that ARF producers sell to a wider variety of skill levels the model is likely set up with the thrust and wing at nearly neutral. And the stab at some slight negative angle. Or the foam might simply be tweaked or the assembly was done not that great. If the thrust line has some upthrust compared to the wing airfoil then that's very likely not right. Or at least it certainly would be wrong for many other designs.
